The Wraith is a "good" stock cooler. It's not great as far as coolers go but much better than any other stock cooler I have used. I asked about the motherboard because even at stock some boards will throttle the CPU back in heavy load situations.
MSI motherboards and the overclocking of FX CPUs don't go well together. The MSI boards just don't seem to stand up to the power draw and heat generated by the FX CPUs. But if your cooling is limiting you to a mild overclock then you might be okay.
On the 212 EVO, Johan is pretty close. I am running my FX8320e @4.2 (no turbo). My 212 has a bit more head room, but not much. It wasn't worth pushing it higher with the summer (and no AC) coming here in Colorado.
