rgone I have skyped him and he has a cm scout case and I've had him turn all his fans in the proper config and exhaust his cooler out the back. I think it may be ambient temps effecting it because I put my nh-d14 back on for him with only one 140mm and I got to
[email protected] before hitting his temps. hes in Australia and its quite hot.
1. I looked at your Rosewill THOR V2 and it is designed very similar to his CM Scout 2.
2. How many fans is he using on the D-14?
3. Is the D-14 mounted so it is blowing AT the rear fan? Is it the stock rear fan he is still using. Seems it was just a so-so fan model and might not pull enough air out of the case.
4. He says 22-23c in his room and that does not seem AU hot.
5. How many other fans are now in use and what are their CFM and speed they are turning. And are they blowing in or out?
6. Like "mandrake" says, he can try removing the side cover and see how the temp does then. I have taken the side cover off and aimed one of those 20in by 20in box fans at the inside of the case just to try and determine what maybe the issue.
7. I am still a little in the dark as to the speed of the cpu when a capture of Hardware Monitor is taken.
8. What video cards are in use?
RGone...
EDIT:
By the way it is usually recommended to keep the CPU Temp at 70c-ish and the Package/Core Temps at about 62c-ish. Those are the temps we have most often used when helping with FX processors in this forum section.
END EDIT.
EDIT 2:
I am going to put this here since I am leaving this computer and can find it here later if I need it.
I went and looked at my air-cooliing runs with my Xigmatek Aegir cooler with two 98CFM fans on it at 4.6Ghz with both fans on full since it was running OCCT P95 Blend and my beginning temp for cpu was 32c and Max cpu temp was 55c. CPU Vcore was maxed during P95 Blend at 1.44Volts.
During that same run of OCCT P95 Blend the Package temp started at 16c and Maxed at 54c with the same 4.6Ghz and max of 1.44Vcore.
My room temp was about 78 to 80F or up to 26.7C. That 10 by 11 ft room had 3 computers running in it and it gets warm for sure.
END EDIT 2.
