- Sep 15, 2015
- Pensacola, Fl
- Thread Starter
- #21
I tried this approach, all the way up to 1.4v and temp/vcore was lowered a fairly insignificant amount. Thanks though. Any other suggestions?The two things I see from your pics are temps and an already high voltage.
Have you tried just upping CPU_NB to ~1.35v ? I do find people tend to overvolt the CPU because of the IMC on theses chips. It's not so much the ram speed but it's density and CPU speed. Both require a bit more CPU_NB voltage.
That's what I'm here for! Thanks for the fresh perspective. I know you're knowledgeable with these chips, and appreciate any suggestions you have regarding getting "the most" out of mine.OK I'd like to try and help you here. Do you mind?
If this where mine, and it is not.... Approach this in a different manor.
An interesting Idea, I have a "thing" about confining everything within the case, but for now(aside from a spot fan here or there) my cooling setup is was it is. Unless you wanna give me that 29x360 koolance of yoursI agree with ShrimpBrime about cutting the top out of the case and mounting the rad and fans outside. That's what I've done on my main ring. It has allowed me to use more powerful 120x38mm fans because clearance to the edge of the motherboard is no longer an issue. Plus, it tremendously relieved congestion in the interior of the case. Things are much easier to work on now. Plus, I just think it looks really cool, like a roots supercharger sitting on top of my computer!
