Ripjaws V and Trident Z should be wider available soon while I will show one one Ripjaws 4 memory kit. This time it's F4-3200C16Q-16GRKD so 16GB DDR4-3200 CL16-16-16-36 1.35V designed for X99 motherboards.
This memory as most available G.Skill kits right now, is based on Samsung IC. Earlier kits were also available on Hynix and I think it was better idea. Soon you will find out why.
Memory has one XMP profile which for some reason didn't work on ASRock X99M Killer 3.1 ( 2 BIOS versions including latest beta ) and Maximus VIII Ranger ( latest BIOS 04 ). In both cases motherboards had problems to start when XMP was enabled. Maybe it's something with the boards or XMP profile, hard to say.
Since XMP isn't working then I won't show screenshot with XMP results as I used to do.
Below is result on ASRock X99M Killer 3.1 using manual settings.
