Hello,
I need some help. Its been a while since i was into this stuff.
So i got a asus rog x99 strix mobo, i7 6800k and the g.skill tridentZ DDR4-3200.
I enabled XMP, then clocked the CPU to 4ghz with the asus AI suite 3.
A few hours later i checked the speed on the ram and it was running at 2666mhz.
If i check the XMP settings in the bios in the AI Tweeker it tells me if the RAM runs at 3200mhz then the CPU will run at 3800mhz
The ram cant run on 3200 mhz on every CPU speed? or is this the AI suite that messes things up
