- Jun 14, 2004
- moving to ohio once 2012 gets closer
I want to make a emergency backup copy of a few of my games such as battlefield 2, wow, and a few others.
My friend to do this.
Copy the game folder onto a dvd or something.
Then go to regedit and search for world of warcraft or battlefield 2.
export any keys you find.
save them and place htem on the dvd too.
incase anything happens to your hd. place the folder of the game you copied onto the hardrive and then run each key. after you try to run each key it will ask you if you want to merge it to the rest of the registry. click yes.
and your done. and your game should work.
is this correcT?
is this correcT?
