bigpoppanick
- Jul 31, 2013
- Florida
Hello this is my first post.
I have a barebones build that I upgraded.
Processor: i5 2500k 3.30ghz (not overclocked)
GPU: GeForce 560SE 1GB DDR5(looking to upgrade)
Ram: 8GBS of Corsair Vengeance DDR3
MOBO: MSI z77a-g45
Case: Chaser MK 1
PSU: Apevia ATX-WA750W Warlock 750-Watt ATX Power Supply
I also have a Thermaltake Bigwater 760 plus cooling only the processor.
I know this is a bargain build. I'm looking to upgrade. My concern is that if I upgrade the graphics card first that it won't give me as much of a punch as upgrading the processor. Or is my processor decent enough that I could upgrade the graphics card and see better performance?
Then that brings me to the graphics card. Would I get better performance out of two of these: http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7889694&CatId=7387 in SLI? or one of these?http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3865159&CatId=7387
How do I compare gpu performance? I know that some cards with the same memory are vastly different, even within the same serial numbers.
Also is the MOBO decent? I had to RA one for a short when I first bought the machine.
I'm looking to eke out some more performance in the most cost effective way. I have a lot of mods i want to do, I want to do a seperate Liquid cooling loop with an independent pump and res for the GPU I end up with, I need to get some SP120 Fans to do the Bigwater push/pull mod, and some more fans. i'm looking to do some LED work too.
The less I spend to get the machine running better the more I'll have for fun stuff. I don;t think I'm that far off from getting this thiung beastly and fun to look at .
MOBO: MSI z77a-g45
Case: Chaser MK 1
