GlobalWin CAK38 Readings?
JAWS
Xtremesystems
I upgraded to bios wz so I could unplug fan 1 from
my mobo. I had to plug in my cak to the p/s. Is
there anyway I can receive the readings from my new
fan, since it's not hooked up to the mobo?
If it hooks to the psu with the 4pin setup,there is an adaptor available which plugs in between the connection with an extra wire which will plug into the 3pin connector on the motherboard .cost about 5 bucks probably have to order it where you got your fan i've seen them but don't remember where
