I haven't put my system together yet as I'm still waiting for the CPU, but I test fit the PEP66 with the Delta fan on my KT7A-RAID and unless you can somehow mount it so the fan is sticking out past the mother board (if its mounted in a regular ATX case it would be pointing up towards the PSU) or rotate the shroud so that its mounted on top (see the KT7 mod on
http://www.2cooltek.com ) then the fan will be right on top of two capacitors.
I also have a question for anyone who has top mounted a PEP66,
[img="[URL]http://www.2cooltek.com/KT7/done.jpg[/URL]"]
why is the opening facing the way it is? if the fan is blowing down (which is supposed to be better) shouldn't the oppening be towards the back right where the exhaust fan is?
