- Nov 5, 2013
- Ottawa, ON
I just got into water cooling like 4 months ago and I don't own a VGA water block because my load temperatures are always in the "average" range and I never bothered GPU overclocking. My friend however, wants to get a water block and do some overclockingbut neither of us know what ones are good or what ones would be compatible with his GPU/Motherboard since we see a lot of incompatibilities. His Maxmius V Formula will be getting replaced but, it will all eventually be the same. He EVENTUALLY within the next 6 months or so wants to get a gtx 780 TI so if there's any block out there that would be compatible with both of those, it'd be great otherwise, I'm going to be recommending he get a r9 290x since we're sticking with the same manufacturer. The reason he's waiting 6 months is finances, could always loan him the money though if there's no way we can get a block compatible with two cards. There's no reason to buy a gpu block then 6 months later have to buy a totally different/new one. It would be appreciated if we could get something compatible from this site:
http://www.frozencpu.com/cat/l3/g30...-Water_Blocks_VGA-VGA_Water_Blocks-Page1.html
Because we live less than 3 hours away from their warehouse and can get next day shipping for like $9. Or drive down and pick it up the same day for like $25 in gas. If nothing's compatible here, just recommend anything that'll work with our mobo/gpu and I'll try to find the cheapest place to get it.
I'm also confused on how it's going to work with our kit (Raystorm AX240) . I know we need barbs/tubing and compression fittings but how they're going to fit into the waterblock,pump, or reservoir or what extra parts we're going to need I've no idea. Like I said, I've only been doing this for 4 months and he just started 2 days ago.
Specs:
ASUS Maximus V Formula
Raystorm AX240 Kit
ASUS Radeon HD 7970 Being eventually upgraded to either 780 TI or 290x
Specs:
Raystorm AX240 Kit
