MisterSilenzo
- Dec 21, 2018
Hi!
Recently I've started to modify my rig so I can settle with new GPU, but first I messed arround researching how to OC. I've managed to OC my i3 530 to 3.8GHZ on this rig before, and my PC looks like this:
i7 875k from i3 530
4x2GB(2x2 Dual Chanel) clocked to 1600 on stock voltage
MSI GT 630 (which I'll swap to 1060/1070 overtime)
500W PSU (AKYGA 500W LPK12-30 which I'll swap with GPU since it's on the "AVOID AT ALL COST" list but with this setup there's should be enough juice)
So what's the problem? The problem is that I cannot overclock my unlocked CPU using multiplayer only because system won't see any changes (and it's propably due to Intel Turbo Boost) any multiplayer above 22 is seen by motherboard but it isn't set, there's also two different clocks on my mobo listed, one as CPU itself and it has clock speed of 133x22, and second as "OS Speed" which on stock settings is 133x24 due to Turbo Boost, also my VCORE is locked to arround 1.32 and scale goes only to +0.302vcore in bios. Tried to change Turbo Boost multiplayer but even with voltage all the way up, after boot system sees 1.32 and then vdrops to 1.288 and then freezes to death. I've got latest BIOS and I've been strugling few days now, any ideas?
@moderator
please merge after i3 530
My cooler is Noctua NH-D14.
i7 875k from i3 530
@moderator
