The whole concept of NUCs and ultra small FF PC's a little misleading in that you have to factor in the space taken up by a beefy power brick.
Why do you say that? It seems to me that it could be the opposite. Namely, that Intel is admitting their GPU products are inferior to AMD's.
What I would be more worried about it it leading to Intel buying out AMD. Not sure if the courts would permit this, howevre.
It raises the question that if AMD had something with amazing performance per watt on the CPU side in the works, why wouldn't they hold off and launch something like this on their own?
But I agree and think that's why Intel hasn't done it already - they'd get smacked down right quick, as Via isn't a serious player and after Apple went Intel, IBM is can be considered totally out of the home consumer market.
Except now they have both and did so since Ryzen's release.That's no secret. We already know that and it has been that way for years. People don't buy AMD components because they have superior performance per watt to Intel. They buy them because they provide superior performance per dollar. And the one edge AMD has over Intel from a performance perspective is in the APU sector. So this collaboration seems in keeping with that. It seems like a tacit acknowledgement on Inte's part that "you do that part better than we do."
..and then there is the 2 series... where IPC is strikingly similar with TDP lower as well as price.
Many reviews have tested that, yes. While there may be some back and forth (not looking to get into your testing, mack), its generally held now that both in multi-threaded applications and single threaded applications, clock for clock they are quite similar. A percent or two I am calling a wash.
The stigma that trents mentioned should, IMO, go away, particularly with the 2 series AMD CPUs. The biggest difference between these CPUs are price and overclocking abilities (or lack thereof on AMD).
My overclocking is stable these days as I don't have the time to clock memory, clock cache, for little gains and more chance of instability.
