HD 7970 mod
Lochekey
Senior Pink Member
So this is by no means anything new and exciting but I figure I would post it up to get help as I go along.
I am going to try to mod my 7970 to see if I can get it performing better. I will be foloowing the concepts laid down by Bobnova here.
So I will be putting this under the knife shortly.
Figure I will start with adding voltage monitoring with a few of these.
Gonna start on this later today so any words of advice in advance would be appreciated.
Lochekey
Lochekey
Senior Pink Member
Got my volt gauges attached. Man are my soldering skills rusty. Need to get a didn't point for my iron.
Lochekey
Lochekey
Senior Pink Member
Thanks Manny im really excited for this one. got it fired up for a second to check the volt gauges and they are working well. Had to order a new tip for my soldering iron which will not be here until wed. so my progress is temporarily on hold. Doing this in hopes of getting a gpu pot in the near future and then taking this thing cold.
Mandrake4565
Mr. Clean Senior Member
This is something I've wanted to try for a while, I have a few older cards I'd like to do this to. Finding the time though will be tough for the time being, so I'm living vicariously through you. A Gpu pot makes things that much more fun. :D
Lochekey
Lochekey
Senior Pink Member
Well the first board is done for:(. Will post pics shortly. I am locking my cat up for the next try might get thinner wire too.
Blaylock
Go Blue!
Ouch! I would continue to practice on that dead board before moving on to the next one. When I did the volt mod to my Giga MoBo I used a Dead MSI board just to practice with those tiny solder points.
"Success follows preparation in equal measures." - Lord Dyrr (R.A. Salvadore)
Blaylock
Go Blue!
I would not recommend allowing the cat to do the soldering on the next one either.
Johan45
Unless something is missing you might be able to clean that up
What were you trying to connect to? The CHIL or pads?
Lochekey
Lochekey
Senior Pink Member
Well I was joking to the resistor connected to the bright up trace. You can see the connection in the below picture[noyt muy const work]. Cat ran across the table while I was trying to clean that connection up and clothelined herself on the wire which resulted in yanking the resistor followed by me jamming the iron into the chil and subsequently my thumb.
Mandrake4565
Sorry but that is funny as $%^& Lochekey! :D I feel your pain though having two of my own they're mischievous lil devils sometimes.
Lochekey
Lochekey
Senior Pink Member
I love my cats but that one almost went out the window.
No the resistor is in pieces.
I was told that I might be able too put an e power board on this to salvage it. Any thoughts on that? Will it work and where can I get one?
Lochekey
Lochekey
Senior Pink Member
Yea I'm familiar with that article. I got to play with one at the get together last summer. Trying to find one is going to be difficult though. I read an article on kingpins suite the other day about a new rev 3.0 version coming out soon. I'll see if I can dig that article up.
Blaylock
Go Blue!
There's a reason cats congregate to circles.
OK back on topic. (In my defense Locke is the official cat herder and I am the official cat hunter)
