The vapors from the liquid condense back into liquid and flow back down into the bottom to heatpipe to repeat the process all over again.
A slight clearification on that statement. You may think that gravity is the reason the liquid flows back because the word down was used. In general, gravity isn't a player in the process. What drives the cycle lazerin describes is the thermal difference plus a capillary effect. It is the capillary effect that moves the fluid back to the hot region for evaporation.
One of the original reasons heat pipes were developed was for use in space to remove heat from a source and radiate it to the cold-vacuum of space. Of course no gravity there.
Consider the hhc001, while mounted initial so that gravity might work (if it were the driver) you then place the mobo on its side in your case. This actually turns the heat pipes flat (or nearly so). Thus if gravity were driving the liquid flow, they would probably not work.
I've not taken hhc001 to inspect it but can only assume that the designers weren't stupid and did build them correctly. However I must say that people do prove me wrong from time to time when I make that assumption.
To answer your question, "how would we know?"
1) An indirect method would be to first find out the fluid being used in the heat pipe and if the pipe is pressurized. Determine the fluid's saturation temperature at the pressure (this ignores the pressure drop in the heat pipe) then measure the temperature at the cold end of the heat pipe both loaded and unloaded. It should be at or below the saturation temperature of the fluid. The problem with this technique is that if the fins were over designed (providing more cooling than needed in this design) you would be fooled by the measurement.
2) A direct method would be to determine the normal operational temps of your cpu (loaded and unloaded). Then cut the heat pipe open, i.e. allow the fluid to escape so they won't work. Then measure the cpu performance again. This would tell you the real answer but you've lost a HS in the process.
Several threads over the last week or so on thermal paste, suggest you read them.
Sorry for the long post!
