Amd X2 4200 Am2 @ FSB 212mhz using Thermalright XP-90C cpu fan ( had a hard time trying to get the retention bracket for this)
Gigabyte M55S S3
Msi 7900gto 512mb/256bit @693/800
Kingston Hyperx 2gb DDR2 6400 4-4-4-12 @ 779.4
CPU-Z 1.37 report file
Processor(s)
Number of processors 1
Number of cores 2 per processor
Number of threads 2 (max 2) per processor
Name AMD Athlon 64 X2 4200+
Code Name Windsor
Specification AMD Athlon(tm) 64 X2 Dual Core Processor 4200+
Package Socket AM2 (940)
Family/Model/Stepping F.B.2
Extended Family/Model F.4B
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
Core Speed 2338.0 MHz
Multiplier x Bus speed 11.0 x 212.5 MHz
HT Link speed 1062.7 MHz
Stock frequency 2200 MHz
Instruction sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, x86-64
L1 Data cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 2 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 2 x 512 KBytes, 16-way set associative, 64-byte line size
Chipset & Memory
Northbridge nVidia nForce 550 rev. A1
Southbridge nVidia nForce 550 rev. A2
Graphic Interface PCI-Express
PCI-E Link Width x16
PCI-E Max Link Width x16
Memory Type DDR2
Memory Size 2048 MBytes
Memory Frequency 389.7 MHz (CPU/6)
CAS# Latency (tCL) 4.0 clocks
RAS# to CAS# (tRDC) 4 clocks
RAS# Precharge (tRP) 4 clocks
Cycle Time (tRAS) 12 clocks
Bank Cycle Time (tRC) 21 clocks
Command Rate 2T
System
System Manufacturer
System Name
System S/N
Mainboard Vendor Gigabyte Technology Co., Ltd.
Mainboard Model M55S-S3
BIOS Vendor Award Software International, Inc.
BIOS Version F4b
BIOS Date 10/31/2006
Memory SPD
Module 1 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Kingston
Module 2 DDR2, PC2-6400 (400 MHz), 1024 MBytes, Kingston
Software
Windows Version Microsoft Windows XP Professional Service Pack 2 (Build 2600)
DirectX Version 9.0c
When i got this well it was on a budget so thought i would sacrifice on the motherboard. Later only i realise the mistake of buying a 800mhz ddr2 for
Amd X2 4200 as at stock i only get 367 and not 400mhz. So i contacted kingston and they told me well i can still set the timings at 4-4-4-12 at 2.0v
at that speed.
So i clocked the FSB at 212mhz and actually can push it to 213mhz via easy tune 5 with the hope of not changing the mem divider in the bios (no option to change in the bios anyway )so that i could get as close to 400mhz. Comp hangs at FSB 214.
Suspect...HT Link which at 1062,7 at 212 and around 1070 at 213.
All Vcore was at 1.35v
Is there any way to increase my FSB as much as possible either till my Ram runs around 400mhz. So far CPU temp has not increased at all.
I tried reducing my HT link to 4x and then changing my ddr2 to 667 so i can go higher FSB...nope failed at 215mhz. So then i thought keep the Ram at 800 and change the multiplier at 10x and HT link at 4x...again nope failed at 213mhz...
Any Solution..
I am noob to this so please help me..TY
Gigabyte M55S S3
Processor(s)
Code Name Windsor
Brand ID 4
Core Stepping BH-F2
Technology 90 nm
Chipset & Memory
Memory Type DDR2
Command Rate 2T
System
System Manufacturer
System Name
System S/N
BIOS Version F4b
Memory SPD
Software
at that speed.
Any Solution..
