- Sep 17, 2002
I'm running an athlon 2200+ and my cooling is terrible. I'm talking like 55 idle with no OC.
So I've decided to get a new hsf. I just got this rig a month ago, first custom comp, so I'm still working out the kinks.
I plan on some OCing, so I'm gonna go with something heavy duty. The 2 that struck me were the SLK800 and MCX4000. They both look good. MCX is aliminum pins with copper base, sounds good. SLK800 I've read has gotten a stable overclock of 2050 mhz on a system similar to mine. I havn't heard any detailed reviews of the mcx4000 other than that it rocks and they've never had better air cooled temps. MCX4000 is more expensive, which generally means better, if only slightly.
Which of these do you think I should get? Any other info that would help you?
Also, I plan on installing the Thermaltake Smart Fan 2 on whichever hs I get. Any better fan reccomendations? SF2 seems pretty good in combination with one of those leet sinks up there with it's 75.7 cfm at max and temp controlled speed. So, if there;s a better fan to get let me know.
Also, within the range of air cooling prices, money is no object.
