- Dec 29, 2003
Hey guys been out of the loop for a while and well i think its time for a new system. Well after doing some looking around on the fourms and what not i decided to go with a DFI bored and a AMD X2. Here is what i picked out so far. I have all the drives im going to use at home. Lead me in the right path
Western Digital Raptor WD740GD 74GB 10,000 RPM Serial ATA150 x2
DFI LANPARTY nF4 SLI-DR Socket 939 NVIDIA nForce4 SLI ATX AMD
BFG Tech BFGR78256GTXOC Geforce 7800GTX 256MB GDDR3 PCI Express x16
Antec NeoPower ATX 480W Power Supply
THERMALRIGHT XP-120 Heatsink
Panasonic Panaflo FBA12G 12U1C 120mm Hydro Wave Case Cooling Fan
OCZ EL Platinum Revision 2 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model
OCZ4001024ELDCPER2-K
AMD Athlon 64 X2 4600+ Manchester 1GHz FSB Socket 939 Dual Core Processor Model ADA4600BVBOX
Thanks for the help
Thanks for the help
