- Oct 22, 2010
- Cincinnati
So, trying to trouble shoot what has become an ongoing and chronic problem with my computer. This is my first build so admittedly I am not super knowledgeable, so I turn to you.
January 15th Computer is assembled, all goes well, its fast, I’m happy: http://www.overclockers.com/forums/showthread.php?t=666481
Some where between then and February 11th I was running through stress tests, and began having issues: http://www.overclockers.com/forums/showthread.php?t=668716
Haha no one replied, oh well…. Within 5 days things had gotten so bad I had to reinstall W7: http://www.overclockers.com/forums/showthread.php?t=669193
My friend had theorized that while stress testing overnight, windows tried to run an update and that possibly that update was enough to push the system to crash leaving me with a fail mid update and thus my problems shortly there after.
February 17th I have to reload windows again when critical updates fail again: http://www.overclockers.com/forums/showthread.php?t=669416
One of the key isseus here is that MSE stopped running, even after I reinstalled it, it refused to run and it was on the SSD.
This is the first time someone points the finger at my SSD but I ignore it because I’m noob…
Things seemed to level off for a bit from there and were going OK, I would have stalled reboots and some random small stuff but nothing major, it seemed odd but I never had anything that windows could not fix for itself in 5 minutes…
Then one day I lose my internet: http://www.overclockers.com/forums/showthread.php?t=672407
It was fine, I restarted, it was gone, tried router, modem, settings, manually turned it on and off in windows, finally did a sefl diagnostic "ping 127.0.0.1" and it returns; unable to contact 80 driver. General failure. So I RMA’d the mobo based on feedback from forum members and was without a comp for 2 weeks +.
Got it back last Sunday, installed, everything was whacky crashes, formatted the SSD and HDD, it seems to run ok form then on, installed a TON of updates without consequence, then I start getting issues again. MSE won’t run again like before, I get constant errors that “windows explorer has stopped running” but as soon as I restart it waits 5 seconds and does it again so I cannot even see my HDD or SSD. I try to get a RAM diagnostic to rule that out and I can’t get anything stable enough to do that and I have gotten 3 windows disk check errors in the last week. Steam stopped running, MSE wont rum, Wexplorer wont run… Windows tried to run a repair and this time it says windows CANNOT repair itself... EEK
So what do you guys advise, I want to enjoy building my own comp but I am very close to parting it out and buying prebuilt, reallllly don’t want too.
