I have been running 2 gigs of OCZ plats pc3200 in the PC in my sig for a while and wanted to try for more. I know the issues with xp32bit only taking 4gb total (including gpu memory), but I still wanted to give it a whirl and see what performance difference I can get.
Anywho, so I bought 2 gigs of Mushkin XP4000 of of SilverSinkSam and they work fine, but I can't get all four gigs to boot successfully or even POST? All the modules work fine separately and the mushkins work together and the OCZs work together, but try and add all four and I get nothing. The four diagnostic lights on my mobo (from sig) light up and the first goes out, but then it halts with three lights left on and I get a tone until I manually restart the process over.
The Mushkin is 250Mhz, the OCZ is 200Mhz. I am ok with them both running at 200 as long as I can get all four to run together.
Any insight, please let me know and thanks ahead of time.
Isaac
Isaac
