Hi im new to the computer building scene and have recently built my own computer which spec's are:
AMD 3000+ newcastle
GiGAByte GA-K8NS with nForce3 250 chipset
Ati radeon X850 pro
and currently 512mb of kingston value ram
I am looking for 2gb of ram setup from newegg or other for around 190$ to spend and i would like the fastest available at that price without overclocking or changing a ton of settings because I went on newegg to get ram and got Very confused at the different timings and such and all but the reason iam getting it is that my mobo didnt seem to want the run 2x512mb sticks and so i figured one was defective and got rid of it because i figured i fried it upon installing (my first comp) and so i wasnt sure if that was the problem but i recently updated my BIOS to the F18 thing for the motherboard which probably could have helped the situation out so i am now looking at the Fastest stock 2gb ram setup for 190$ or less and the ram that my motherboard says that i can fit is: 3 184-pin DDR DIMM sockets that support up to 3gb max and support DDR400/333/266 DIMM and supports DDR DIMM but that is all i know and i would appreciate it very much if you could help me make the right choice first instead of being sorry later
thanks for your time,
LJ
AMD 3000+ newcastle
Ati radeon X850 pro
LJ
