I'm getting back into watercooling after years away. The last time I overclocked and watercooled was with Intel 805 cpu. I'm quite sure a lot has changed since then.
I have a D4 pump with molex 4pin connector and a MicroRes. I have a very old i5 3570k and EVGA 1060 FTW.
I've been waivering between:
1) getting a radiator and CPU block and get watercooling up and running while learning watercooling and overclocking again. After 3060ti or 3070 is readily available then I'd build a new computer.
2) build a new computer with watercooling and overclocking but take my time in doing so. I've also started a new woodworking hobby and would like to build an open, wall-hung art piece. I'd take my time building the new computer. Get the motherboard and cpu right away. But then measure the motherboard for my wall hung setup. Use a router (woodworking, not networking
) to rig up a base with hidden cables, etc.
End goal for watercooling and overclocking aren't radical. Just some mild clocking to eek out a little more oomph. I'd like it to be visually pleasing and leave open the freedom to clock more aggressively down the road. I use the PC mostly for the gaming I have time for and as a media center. I have a pretty nice surround sound setup in my study. So end goals are pretty tame: games, media center and a wall hung modern art water cooled PC.
I've narrowed my new computer to i5 11600k or KF and a suitable mobo in the $200-300 range. Once stock and prices come back to normal I'll get a 3060ti or 3070.
Watercooling parts I'm considering are an EK 360 radiator either PE or XE and most all of the EK blocks are pleasing to look at. If I'm only mildly clocking do I really need the thickest 360 radiator I can get? Does the CPU block really matter all that much so long as I get a reputable brand and it has a good flow rate? Are a couple degrees hotter going to matter if I'm not pushing the envelope, living on the edge, etc etc? Can I pretty much just get a block from a good company which creates the design/look I decide to go with?
I have a $15 off at Newegg through PayPal coupon which expires 6/12. If I spend just over $100 and use my PayPal account I get a $15 coupon. I'll probably get something this weekend. Whether that is PC hardware or watercooling hardware I have not decided.
All thoughts are welcomed. Effective and good looking block advice is appreciated. Advice on how crazy I need to get on radiator thickness is appreciated. Advice on a quality mobo in the $200-300 range is appreciated. Also on my D4 pump can I simply splice on a 2 pin harness and draw power from my motherboard rather than get a molex connector adapater? I need to look on my existing motherboard to see what it's pin setup is.
