- Mar 24, 2012
- at the moment Rep dominicana
Hi do need help with my overclock.
I have tried to get my PC stable ad 3800 Ghz. The test’s that I run prime95 14 hrs and 10 hrs blend are =OK, Memtest 7 hrs 10 passes =OK, Intelburn 10 runs “high” = OK. OCCT 1 hr large data= OK , Buth when I run FSX my system reboots. I don’t know if FSX beeing on a different drive (SSD) is the problem?
Hope some one can help me solve this and get my system stable.
This are my settings:
CPU Level Up = Auto
Memory Level Up = Auto
AI Overclock Tuner = Manual
CPU Multiplier = 9.0
FSB - Memory Clock Mode = LINKED
FSB - Memory Ratio = SYNCED
FSB (QDR) MHz = 1690 = (423) MHz = 3600
MEM (DDR) MHz = 1690
LDT Frequency = 5x
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = Auto
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 = enabled
P2 = enabled
tCL ( CAS Latency ) = 9
tRCD = 9
tRP = 9
tRAS = 24
Command Per Clock (CMD) = 2T
tRRD = auto
tRC = 34
tWR = auto
tWTR = auto
tFAW = auto
tRD = auto
tRTP = auto
tRFC =auto
tREF = auto
Over Voltage
CPU Voltage =1.32500
Loadline Calibration = disabled
CPU PLL Voltage = auto
CPU VTT voltage = auto
Memory Voltage = 1.66
NB Core Voltage = 1.40
SB Core Voltage= 1.50
CPU GTL REF0 Ratio = Auto
CPU GTL REF1 Ratio = Auto
CPU GTL REF2 Ratio = Auto
CPU GTL REF3 Ratio = Auto
NB GTL REF Ratio = Auto
DDR3 CHA1 Ref Volt = Auto
DDR3 CHB1 Ref Volt = Auto
DDR3 CHA2 Ref Volt = Auto
DDR3 CHB2 Ref Volt = Auto
CPU Configuration
CPU Internal Thermal Control =Auto
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled enabled
CPU C estate Capability = Disabled
Execute Disable Bit = enabled
Virtualization Technology = enabled
Enhanced Intel SpeedStep(tm) enabled
CPU Core 2 = Enabled
CPU Core 3 = Enabled
CPU Core 4 = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum =Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
AIDA64 readings
VOLTAGE BIOS set FSX OCCT
CPU core 1.32500 1.344 1.312
VTT auto 1.216 1.216
PLL auto 1.520 1.520
NB 1.40 1.424 1.424
SB 1.50 1.488 1.488
DIMM 1.66 1.696 1.696
regards,
Capie
CPU Level Up = Auto
LDT Frequency = 5x
P1 = enabled
P2 = enabled
tRCD = 9
tRP = 9
tRAS = 24
tRRD = auto
tRC = 34
tWR = auto
tWTR = auto
tFAW = auto
tRD = auto
tRTP = auto
tRFC =auto
tREF = auto
Over Voltage
CPU Configuration
AIDA64 readings
NB 1.40 1.424 1.424
SB 1.50 1.488 1.488
regards,
Capie
