- Mar 12, 2002
Ya your not going to want to try drilling holes with a dremel you will just smoke out the bits. If theres a harbor freight nearby you can get one of those stepper bits for about $6. They dont last as long as a good greenlee or irwin bit, but they get the job done if you wont be using it alot. Alternately any high speed TiNc coated bit or high carbon steel bit should do the trick. A 1/4" bit usually has a 1/8" pilot blade so its acceptable to use as a 1 off for drilling that hole. Side note when drilling holes in sheet steel WD40 is your friend. It will help keep the steel from heating up and shearing instead of cutting, ATF is also pretty good for this but it makes your drill bits stink.
