Ya know, there's a search function on these forums for a reason http://forum.oc-forums.com/vb/search.php?s=
Check out the Nvidia section. There is a sticky about various GeForce O/Cing results. As for ATI, I'm sure there are threads about ATi and O/Cing too...
Really the difference between the two isnt that much. If I were pressed though I would say that a real 8500 (non LE) has more potential for higher performance. But I wouldnt swap cards.if you already have a TI500.
well the difference really just isnt that big. it wouldnt be worth the effort of switching. If you want to upgrade then at least upgrade to like a 9500Pro
Good lord, that's pathetic. I'm not even close to figuring out what that is supposed to say (other than the lazy part, and it makes not care about the rest).
