- Jul 12, 2002
- Buffalo, NY
Hi,
I would like to know if I can overclock my video card. It's called the Riva TNT2 by Nividia and it has 16mb ram and it is located in the APG socket. It's in a Gateway P3 600mhz Performance series desktop with 320mb Sdram. I would apreciate any information you can give me about how to overclock my video card. Below are some additional specs on my video card.
SiSoftware Sandra
Device Information
Device Type : VGA Display Adapter
Device ID : bus 1, device 0, function 0
OEM Device Name : Nvidia Corp RIVA TNT2 Model 64 [NVM64]
OEM Hardware ID : FUN_0, VEN_10DE, DEV_002D, REV_15
Product Device Name : Visiontek RIVA TNT2 Model 64 [NVM64]
Product Hardware ID : VEN_1545, DEV_0005
Revision / Stepping : B / 6 (21)
Power Management Capabilities
Version : 1.00
Supports Clock Slow-down : Yes
Supports D1 PM State : No
Supports D2 PM State : No
Supports PME# : No
Supports PME Clock : No
AGP Capabilities
Version : 2.00
Command Queue Length : 32
FW Transfers Support : No
Over 4GB Addressing Support : No
Side Band Addressing Support : No
Data Transfer Modes Support : 1x 2x 4x
Device Properties
Latency Timer : 248 clocks
I/O Access : Yes
Memory Access : Yes
Bus Master Capable : Yes
Special Cycle Recognition : No
Memory Write & Invalidate : No
VGA Palette Snoop : No
Parity Error Response : No
Address/Data Stepping : No
System Error Line : No
Fast back-to-back Transactions : No
Detects Parity Errors : No
Supports System Error Line : No
Supports Parity Line : No
User Defined Format : No
PCI 66MHz Bus Support : Yes
New Capability List : Yes
Device Select Timing : Medium
Multi-Function Device : No
Header Type : 00
Programming Interface : 00
Hardware Resources
Memory Address : 16000000
Memory Address : 14000000
IRQ Line : 11
INT Pin : A#
Dynamic Management : Yes
SiSoftware Sandra
Device Information
Version : 1.00
Supports PME# : No
AGP Capabilities
Version : 2.00
Device Properties
I/O Access : Yes
Memory Access : Yes
Header Type : 00
Hardware Resources
IRQ Line : 11
INT Pin : A#
