How Long Do I Run Toast?
Shroomer
member with no avatar
Ohio
Normal priority will slow down your computer and cause it to be close enough to max load.
15 minutes to half an hour should have you within 1c of your max temp. I always add 1c for good measure.
IFMU
The Xtreme Senior Nobody
Quick question... Ive had that and I think Ive lost it.. where could I get it again?
takiwa
23 Instructions in 8.04 CPU CLOCKS???
Mine usually says somewhere between 1500-2000 CPU CLOCKS...on occasion it will drop to 1000-1100...
takiwa
I never noticed that before, but you're right, it does drop over time...:D 8 clocks is still good, though;)
