that can be done if you have NTFS partition
1. Go to folder options
2. From
Tools -> Folder Options -> View Uncheck
Use Simple File Sharing (Recomended) its checked by default (you can find the setting right at the end.
3. Right click on your NTFS parition / folder you want to protect
4. Click on
Properties ->
Security
5. You see a list of users which are granted different rights
6. Add / Remove modify user's and their rights
For instance there is a folder
Temp on your NTFS partition C: which you want that only you can browse, than follow the procedure i stated above, in the user's list remove everyone and add your user account only, that should do
If in case you manage to screw things (like i did
) than you can fix that easily, i managed to get myself locked out of my files, the way out is to take owner ship
The following procedure is only in case you manage to lock yourself and can't access the files
1. Follow the same procedure above and go to security settings
2. Click on
Advance
3. Go to
Owner
4. Click the lil check box down which says
Replace owner on subcontainer and objects
5. Press
Apply
you will get ownership of the files
In case you have FAT32 partition
Than the only solution which comes to my mind would be using some 3rd party software like Folder Guard Pro or something, you can get such softwares from
www.download.com
hope that helps
