- Jan 3, 2005
Update on my situation. i flashed it with the empty.bin and then back to my original. this put it back at 12 pipes and it seems to be back to normal. still wanna try to get the 16 pipes then pencil mod and see what i get.
xslashpract said:ok will do i should be getting a multimeter here in the next few days and then i just gotta find that 2b pencil at staples or somewhere. other than staples do yall know of a place that carries them?
xslashpract said:i did the pencil mod and everything went fine got it to 1.45 no sweat. but i cant boot windows. it goes all the way to the windows loading screen then right after it restarts. i can boot safemode and if i uninstall my drivers in safe mode and then restart it works fine. should i erase the pencil mod cause to me that seems like a weird problem to have just by upping the voltage
UPDATE: i erased the pencil markings. im back at stock voltage and it works fine now. i can boot into windows with drivers no sweat
dcarr1971 said:Something to note: Prior to attempting the Softmod I was having problems with the card crashing whenever I'd run any apps using 3D graphics, so the card may have been a piece of junk anyway. I figured I had little to lose going into this, so I have no qualms about trying to RMA the card. (I had hoped that the XTPE bios might make the card a little more stable with the added bonus of being faster.)
At this point I don't know if the softmod caused the problems or if the problems kept the softmod from working. Any suggestions would be greatly appreciated.
xslashpract said:how much heat more heat should i expect? with load my card doesn't break 51c. didn't think the higher voltage would push that much farther
micamica1217 said:once hosting is complete, this should be a sticky.
nice job.
mica
