- Sep 22, 2003
- Detroit, MI
Post a printscreen of the next pop up you get so we can see the type of window its in.
autoMATTic said:Post a printscreen of the next pop up you get so we can see the type of window its in.
IMOG said:You all are just doing the run around when all pollux needs to do is...
POST THE HIJACKTHIS LOG!
IMOG said:You must install stylexp from the utility, or it will recreate itself.
IMOG said:I believe it does also. Most all of that stuff is junk... Doesn't windowblinds come from stardock?
Stardock is really terrible.
Is skinning your windows really that important?
There is probably something that is safe, I believe there is something that patches a theme file which just allows you to add more themes, but uses the standard windows display properties appearances tool. It doesn't come with any spyware loaded application.
thanks. i removed them all except stylexp. are there any other safe and free utilities i can use to configure my xp theme?
ashenfang said:you know I have always wondered, itsn't spyware, malware, ect illegal? I mean it is a program being installed on your computer with out your consent???
