- Jul 5, 2003
- Frederick, MD
Dunno 'bout the L35 impellor, but the L30 II impellor DOES work in the L30 I.phaeton said:Will a L35 or L30II impeller work in the L30I?
Bios24 said:Upon further research, the Mag 3 might be too loud for me. I might opt for the L35 instead. Anyone have experience with both? It's a $10 difference.
Cyrix_2k said:Dunno 'bout the L35 impellor, but the L30 II impellor DOES work in the L30 I.
Question out of curiosity: did you glue the impeller to the magnet ? Because i'm on my 2nd shaft (first one burnt out due to user error - i let the pump on without water overnight, error during bleeding) and this one has lasted for 4 years now, without a hint of rattle. The first one was good too before i destroyed itRi0 said:L30II (mine) did not have a ceramic shaft. It wasn't a user error, the impeller was seated correctly, but there was too much wiggle. Every time it would start up you could here a rattle and it would settle out.
How do you know the L35 shaft works in the L30s? Thorilan said he thought it would work, but wasn't sure.Ri0 said:L35 works in the L30II
L30II (mine) did not have a ceramic shaft. It wasn't a user error, the impeller was seated correctly, but there was too much wiggle. Every time it would start up you could here a rattle and it would settle out. After about 3 weeks time the plastic hole that the shaft went through on the impeller wore and looked like the outline of the figure 8, and it would rattle very badly. The L35 corrects this.
The L35 uses a unidirectional impeller and the new motor assembly used 19W. The L30 II uses a bidirectional impeller and the motor uses 27W. I do not believe the impellers are interchangeable due to the redesigned motor on the L35
Got mine for around 12€. But it live 50km away from Italy.. guess that helps Got my pump, round Eheim elbows (just *great* for routing tubes), and replacement parts at a local pet shop that's specialized in aquariums.Cyrix_2k said:Cool. Where did you get the new impellor? I'm trying to locate one for under $15... Guess I should e-mail Hydor sometime...
Cool. I'll have to check my pet shop "fire house pets" sometime. Problem is they're only open during normal work hours and I don't have a drivers license. (I'm 15 years old. Close, but no cigar)SureFoot said:Got mine for around 12€. But it live 50km away from Italy.. guess that helps Got my pump, round Eheim elbows (just *great* for routing tubes), and replacement parts at a local pet shop that's specialized in aquariums.
Cyrix_2k said:Just a note to other people: If your L30 starts rattling, DO NOT KEEP RUNNING IT. My pump appears to have died last night after rattling for approx. 1 month. The best part is that it did quiet down over the past few days; it wasn't silent, but it wasn't nearly as loud as it had been. I flipped my surge protector on and off and the pump didn't come on so it either died or it's jammed. Either way it DID turn off when my computer was still running Also, the body of the pump is VERY hot, so I guess the motor's still good, but the impellor's dead.?.? Time to go see how much damage was done to my system...
Korndog said:mag 3 is not loud..
i run 21dba panaflos and i can't hear it. Now without the padding, i can hear it so just make sure u put some padding under it (almost anything works, i've even tried a tube of toothpaste).
