JeffnWV said:I flushed my rad and it turned the vinegar from clear to milky and had lots of floaters in it.
NoKtEm said:how do you flush it without putting it through the pump?
or do what alot of guys do, get a secondary cheaper pump just for flushing, cleaning and filling your system.NoKtEm said:how do you flush it without putting it through the pump?
khriez said:Crap, I may have to buy more tubing because if I remove my current tubing - which is 7/16" ID Masterkleer, it will be loose and I'll have to cut off that end. It may still be long enough to re-assemble the setup.
Can the Laing D5 pump be submerged? I am thinking of running the pump right under running tap water and to the radiator to flush. I'm really not sure what I'm doing.
I don't see any weird residues inside my tubing though...........
pak said:I would think you are ok. Are you only water cooling your video card?
--pak
