- Jan 28, 2011
- Delaware
Hiya all, I hope everybody is well today, I am sick of snow so I am working on this HTPC I am still building, stuck though:
My specs:
Asus m4a785-m
Amd Phenom x3 8450e 2.1ghz (factory)
HT ref. clock (bus spd) 240 mhz
core speed 2.52 (oc)
core multiplier 10.5x
core voltage 1.25
NB speed (ht link) 1920 mhz
NB Mulitplier 8x
6gb PNY xlr8 pc2-6400 ddr2 at 1.9 volts confirmed running dual channel
memory Frequency 399.64 (400)Mhz set at 333mhz in bios
memory set at 4-4-4-12 per mfg.
My results:
My FSB-DRAM per CPU-Z is 3:5
I keep seeing 1:1 as being"what you want"
but the system is stable (4 hrs now,still running Prime)
And 5 hours on AOD Utility Stability Test passed fine.On every other configuration I have had yet, the calcuation tests fails everytime !
The AOD Utility software has it at over 6000 which is the best
I have done yet. I get FSB-DRAM 1:2 with bios set at default (only memory set at correct speed, everything else at AUTO).
Nothing is overheating, it's all just right where it has always been, checked, checked and rechecked. My o/s is responding fine (even my AVI,which normally hates any changes to memory freq which is strange).
My Questions:
What am I doing wrong ?
I assume the cpu is the bottleneck ?
This is hard on the memory ? Damaging ?
Have I hit the "sweet spot" I have been looking for ?
Asus M4A785-M mobo Amd Phenom X3 8450e 2.1Ghz AM2+ cpu
EVGA GTS 450 (Fermi) FPB 1gb DDR5 gpu
Cooler Master Hyper N520 Copper Heatpipe CPU cooler
6gb PNY XLR8 pc6400 ddr2 Thermaltake V3 Black Edition case
Windows 7 Ultimate 64bit
My specs:
Asus m4a785-m
core voltage 1.25
NB Mulitplier 8x
My results:
My Questions:
