Hello All!
I am fairly new to overclocking, and just have a few questions. First of all, I achieved a stable overclock of 4.5GHz using the settings listed below, but I was wondering if there's another way to set the voltages either using offset or manual mode. The reason is, I followed several guides to set these settings, and am not sure if they are the best for overclocking. Also, when the system idles, the frequency and voltage never decreases. I know that it's supposed to be 1.6GHz @ 1.0v when idling, but my computer is always 4.5GHz @ 1.336v. Another thing, when playing games and running other CPU-intensive software, the voltage decreases to 1.296v, and sometimes causes a BSOD. The only BSOD error code I get is 0x124, which means too little Vcore. Can someone help me out and let me know what settings I have that are incorrect/not optimized for the overclock I have applied? I have a good aftermarket air cooler, so the temps are 24C when idle and ~50C when under load.
Thanks all!
Hardware:
ASUS P8P67 PRO (Rev. 3.0)
Core i5-2500K
Corsair Vengeance RAM (16GB, 4x4, 9-9-9-24 2T)
GTX 580
UEFI BIOS Settings:
Ai Tweaker
Ai Overclock Tuner: Manual
BLCK/PCIE Frequency: 100.0
Turbo Ratio: By All Cores
By All Cores: 45
Internal PLL Voltage: Enabled
Memory Frequency: DDR3-1600MHz
DRAM Timing Control: use the rated timings
EPU Power Saving MODE: Disabled
Ai Tweaker\ CPU Power Management >
CPU Ratio: Auto
Enhanced Intel SpeedStep Technology: Enabled
Turbo Mode: Enabled
Long Duration Power Limit: Auto
Long Duration Maintained: Auto
Short Duration Power Limit: Auto
Additional Turbo Voltage: Auto
Primary Plane Current Limit: Auto
Ai Tweaker (in the DIGI+ VRM section)
Load-Line Calibration: Auto
VRM Frequency: Manual -> 350
VRM Spread Spectrum: N/A
Phase Control: Extreme
Duty Control: Extreme
CPU Current Capability: 110%
CPU Voltage: Offset
CPU Offset Sign: -
CPU Offset Voltage: 0.015
DRAM Voltage: 1.50
VCCIO Voltage: Auto
CPU PLL Voltage: 1.8
PCH Voltage: Auto
CPU Spread Spectrum: Auto
Advanced\ CPU Configuration >
CPU Ratio: 45
Intel Adaptive Thermal Monitor: Enabled
Active Processor Cores: All
Limit CPUID Maximum: Disabled
Execute Disable Bit: Enabled
Intel Virtualization Technology: Disabled
Turbo Mode: Enabled
CPU C1E: Auto
CPU C3 Report: Auto
CPU C6 Report: Auto
Thanks all!
Hardware:
Core i5-2500K
GTX 580
UEFI BIOS Settings:
Ai Tweaker
By All Cores: 45
CPU Ratio: Auto
Turbo Mode: Enabled
CPU Voltage: Offset
CPU Offset Sign: -
DRAM Voltage: 1.50
VCCIO Voltage: Auto
PCH Voltage: Auto
CPU Ratio: 45
Turbo Mode: Enabled
CPU C1E: Auto
CPU C3 Report: Auto
CPU C6 Report: Auto
