I purchased parts for a new PC back in November and started building early December. Despite nearly three months of effort, including two RMAs and a second RAM kit, my CPU seems even less stable than before. In fact, every time I think it's stable, it seems to suddenly become highly unstable. That is, I'll find BIOS settings which will let it run MemTest86 and MPrime (Prime95 for Linux) for hours on end, but then the next day, I'll try again and MPrime will repeatedly fail within minutes. I started with an undervolt via IA AC and IA DC and a static VCache offset. I was able to run MPrime with `IA AC = 0.19`, `IA DC = 1.02`, `VCache = -0.05`, RAM at DDR5-7000, and everything else at "ASUS stock" settings for about 12 hours before I patted myself on the back and called it stable. The next day it was anything but stable. Since then, over the past two months, I've been slowly increased the voltage from there and reduced the power until it was running at Intel stock with no undervoltage. Then yesterday it started failing MemTest86, too, something it had been passing consistently for over a month.
I've replaced the CPU, motherboard, ASUS themselves saying it was either the CPU or motherboard after a lot of back and forth and trying an entirely different RAM kit and different BIOS. With current settings and my overkill cooler, temps stay below 80°C under even the heaviest load, which lately isn't very heavy since the CPU can't clock up to it's advertised turbo speed (5.2GHz on P-core/3.7GHz on E-cores). In case it matters, both CPUs had an SP rating of 72.
The only thing I can think of is it's the PSU, but before I submit yet another RMA request, I wanted to ask all of you what you think. I've been building computers for over 20 years, but I've never encountered a run of problems like this.
