- Jun 12, 2011
In high humidity environment cover open or close? or don't matter?
What''s your humidity like?
The silcon conformal we use isn't sticky after it dries.
so it is fully curing. i should switch. which one for the least ammount of insulation?
adding: can you just spray it on card contact areas like PCI slots without having contact problems?
i would love to get something that cures in spray that is very thin (assuming i get it on right)
and cured, for coating some things that are outside here, like the screws on my solar pannel and all.
and something to recoat heat syncs thinly.
is there a brand and name of a coating that that would go on real thin and cure solid without baking or UV, that you used?
