Im a bit busy because my Skyrim seems to be upset because of to many mods (hello CTD...).
You can read some of the stuff at
http://www.tomshardware.com/reviews/crucial-m500-1tb-ssd,3551-13.html they offer some comparison and a few explantions regarding the difference between those 2 drives.
When it comes to my personal view:
Opal 2.0 encryption: Its simply for security purpose, when you are encrypting a drive which is the same action such as the MS bitlocker is doing, you may increase security in theory. Although bitlocker is only available on professional or ultimate editions in usual, so its not truly usable for a majority of the users who dont own a "special edition of the OS". However, Opal 2.0 as far as i know is a more powerful encryption, so in term someone feels the need for it they will have a powerful encryption handed out by buying a M500 drive. However if you want to know my honest view regarding encryption which is more of a philosophical view: In a practical environment, away from the theoretical number crunching (harder to access = more secure), a encryption isnt more safe than no encryption at all. Because as soon as someone is using encrytion they are drawing "bad moths" inside theyr data because it kinda will mark a "bright bulb" inside a dark room. "Bad moths" dont enjoy data that is easely available to them, they want to crack and hack data and as better the data is protected as higher the effort they are doing in order to spy out that data. So ultimately you are only doing yourself some troubles by decreasing the "easy access" to your own data but overal security wont necessarely be improved. So, a encryption is a feature but not necessarely useful... Although, the M500 got a hardware based AES 256-bit encryption engine and that means it can execute encryption without any performance loss, thats surely pretty interesting in term someone feels the need for encryption.
Power loss protection: Basically, lets say your power goes off all of a sudden due to different reasons (akku destroyed, general power cut, damaged hardware or whatever) without backing up your data any of the data cached inside your SSD will be destroyed and it may cause data corruption, the most nasty ones would be OS related. Usualy a good OS got many data protection technologys on its own against sudden power loss. However, its not failproof and a OS is still able to be damaged in term the SSD was in the progress of writing cached data. Because the cache itself is a volatile environment, as soon as the power is turned off, those data will be destroyed (comparable to RAM). In theory you can disable the data cache of a SSD but this will greatly reduce performance, so it will truly hurt your overall performance and thats not recommended. Luckily, such a action isnt required in term a SSD got a power loss protection, so in term there is a power loss the SSD data cache wont be destroyed, it will still be able to write down its cache to the NAND thanks to the special capacitors backing up the volatile cache. Those capacitors are sometimes described as "supercapacitors" because they have some unique ability to store lot of charge in a very small environment, so its not a cheap cap, its some enhanced stuff (for example tantalum cap). That capability can greatly reduce the risk of critical data loss because the "volatile" cache is protected and the non volatile data is usualy already written somewhere. So it can be useful in order to protect against corruption, surely a good feature.
Cross-die redundancy: This feature is also known as "RAIN", Microns (the manufacturer of the NAND used on the M500) trade name for cross-die redundancy. Its kinda the same such as the "RAISE" feature used on Sandforce based SSD controllers. Its able to protect from partial loss of NAND cells, so that means its able to recover a certain amount of damaged NAND cells inside a certain NAND module. However, its unable to recover a entire NAND module in term the whole NAND module would be damaged. So its not the ultimate protection but in many terms just a certain part of a NAND module could be damaged and not the whole NAND module. In that term that technology is pretty useful and it truly would be able to safe your data. So you will certainly have some increased security, thats clear. Sure, there is many options in order to increase security against all kind of data loss, however, those solutions can be pretty expensive (and users buying a inexpensive SSD arnt the ones having to much bucks to spare) and thats the point why a "build in" protection is able to grant some more security at zero cost, so its simply a free bonus.
Anyway, so you see its not just all about "raw speed", utility is another thing to take into consideration. Checking out Newegg
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148694 the price isnt that spicy (although i got my drive cheaper than that). Finally its your choice but i think its good to know all the available options and dont let the raw speed of the EVO blend your eyes to much.
There isnt truly "slow SSDs" anymore nowadays (at least not in the 240 GB range), just SSDs expensive or cheap and some with good or bad utility.
