TT120 (Apr 28, 2001 08:18 p.m.):
It just hooks onto the 2 middle lugs on your socket and tighten it down with the little wing nuts. Be VERY careful not to over tighten them tho. I have broken off 2 lugs on 2 different MoBo's by giving them that extra little twist to make sure it's on there good. Big mistake. I lost a 1.2 CPU this way, when the lug broke the waterblock came off the chip (the comp was on and I was watching the temp while adjusting the hold down to make sure the waterblock was on the chip flat) Those lugs cant take very much pressure before they break.
Instant death, like 3 seconds. I reached for the power cord to yank it out but it was too late. Dead bird.Door Knob (Apr 28, 2001 08:34 p.m.):
Thats harsh(watching it die like that), just curiose, how fast those temps rise. Probably almost an instant death I am guessing.
I think you mean the 'top' of the chip, and yes it should touch the top of the chip. In fact, make SURE it touches the top of the chip or you wont have to worry about it any more. The little bubbles will eventually go away. They will accumulate in the reservior (aluminum housing)peewee (Apr 28, 2001 08:34 p.m.):
i'm just worried about crushing the cpu, shold the block touch the bottom of the cpu?. also is it ok to have little air bubbles in the lines?. i hooked it up on my table to test it and i added water but still had little tiny bubbles in the line, the aluminum housing that the pump is in came with a round oring to seal a square box?. any ideas how to do that?
bdf24 (Apr 28, 2001 10:21 p.m.):
I could be mistaken but I think the only real benifit of sealing off the reservoir is to prevent it from leaking or spilling due to moving the pc around or bumping it. Without sealing it you could forget that the reservoir is in there and say tip the pc over to dig around! OUCH!!! That would hurt!
So if you are going to keep it in the pc, I would recomend sealing it off!
dunno260 (Apr 29, 2001 01:21 p.m.):
Also, have radiator right before the cpu in the tubing order so you have the coolest water going to the cpu.
