vdpaupp
VDPAU video post processing. Works with --vo=vdpau and --vo=opengl only. This filter is automatically inserted if deinterlacing is requested (either using the d key, by default mapped to the command cycle deinterlace, or the --deinterlace option). When enabling deinterlacing, it is always preferred over software deinterlacer filters if the vdpau VO is used, and also if opengl is used and hardware decoding was activated at least once (i.e. vdpau was loaded).
sharpen=<-1-1>
For positive values, apply a sharpening algorithm to the video, for negative values a blurring algorithm (default: 0).
denoise=<0-1>
Apply a noise reduction algorithm to the video (default: 0; no noise reduction).
deint=<yes|no>
Whether deinterlacing is enabled (default: no). If enabled, it will use the mode selected with deint-mode.
deint-mode=<first-field|bob|temporal|temporal-spatial>
Select deinterlacing mode (default: temporal). All modes respect --field-dominance.
Note that there's currently a mechanism that allows the vdpau VO to change the deint-mode of auto-inserted vdpaupp filters. To avoid confusion, it's recommended not to use the --vo=vdpau suboptions related to filtering.
first-field
Show only first field.
bob
Bob deinterlacing.
temporal
Motion-adaptive temporal deinterlacing. May lead to A/V desync with slow video hardware and/or high resolution.
temporal-spatial
Motion-adaptive temporal deinterlacing with edge-guided spatial interpolation. Needs fast video hardware.
chroma-deint
Makes temporal deinterlacers operate both on luma and chroma (default). Use no-chroma-deint to solely use luma and speed up advanced deinterlacing. Useful with slow video memory.
pullup
Try to apply inverse telecine, needs motion adaptive temporal deinterlacing.
interlaced-only=<yes|no>
If yes (default), only deinterlace frames marked as interlaced.
hqscaling=<0-9>
0
Use default VDPAU scaling (default).
1-9
Apply high quality VDPAU scaling (needs capable hardware).
