- Jul 27, 2018
- Los Angeles
I feel bad for those who pulled the trigger a little soon.
Intel is set to release their Core i9 9900K late August or September, the new mainstream 9th generation flagship model has appeared in 3DMark, with specs and a score and everything.
The eight-core CPU scores 10718 points in the Time Spy CPU test. When you isolate and compare that number a bit back and forth, you can compare it compare with say a Ryzen 2700X, which is at 9147 points, Intel's Core i7 8700K scores an average of 7918 (all at defaults). That's 25% more cores, and 25% more CPU performance.
Now release a 32 core CPU with the 9900K speed and OC of 5Ghz. That would be virtually 64 threads 5Ghz a pop, The 3 thousand dollar CPU. I mean the 18 core right now is 2 thousand.
