Hey all, sorry that this post is another one of those "help me with my new build"... This is kind of my first post on these forums and my first serious build!
So yeh, ive got a budget of about $1400 AUS (i'll go over it a bit if i think its justified), and basically i'm fairly happy with the components thinking of so far, im just wondering about CPU.
I was considering going a higher end dual core, but i figure I'll be doing a fair bit of multi tasking and highish end gaming so im starting to lean towards a quad? also im banking on more apps coming out that will utilize a quad...
I've looked around in my area (my under 18, so where i live there isn't much option for buying with credit cards off the net) and I've been tossing up between a Intel Q6600 or a Intel 9450. I'm also leaning towards the 9450 because it seems to be reasonably priced at $280 dollars (best i could find in my area). Is this a good move?
Figure i should throw in a few other major pieces I'm considering:
ATI 4850 (one for now, cross fire later)
4 GB DDR2 800mhz RAM (should i be looking higher? i think i should but this stuff is well priced and reasonably low latency, will probably go 8GB when i get a different OS)
tossing up within the ASUS range of mobo's..
coolermaster centurion 5 case
Seagate 7200 500GB SATA2
460 W PSU, (will upgrade but comes with the case in a nice little bundle)
So yeh! any help with the CPU would be great! (or component recommendations if you like)
