- May 27, 2002
- Ohio
ok, about a week ago, my computer started acting weird...
I would just be browsing the forums, nothing that uses alot of power, or RAM, or HDD usage. And suddenly my monitor goes blank, tells me there's no video. and the PC locks up.
When this happens, it sounds like the fans in my PC suddenly get louder. like they are suddenly spinning faster.
I don't think its my video card. i'v been playing ALOT of games on it, running it pretty hard, and have yet to ever have a problem.
BUT, that video card is only like...2 weeks old i'd guess. its a 6800se. Which requires a 4 pin molex to be plugged into it. Unlike my old Video card, which didn't need the extra power.
So i unplug a couple extra fans i have ( that do nothing more than blow cool air onto the HDD's, and then suck that air out of the case. ). and since i unplugged them, i havn't had this problem happen to me since.
on motherboard monitor 5, its showing my +12 volt rail at running 11.67 to 11.80 volts.
is that voltage to low?
does this sound like a PSU problem? just wondering. since this doesn't seem like a HDD, RAM, or Motherboard problem. And i don't think its the video card itself. If anything, the new video card thats added to my system is drawing more power than the PSU can handle.
its an Orion, rated at 420 watts.
17 Amps on the +12 volt line, +36Amps on the +5 volt line.
I have 2 regular IDE HDD's installed, a SATA drive installed and a DVD/CD burner. DFI Lanparty B motherboard, 6800se video card, a 120mm fan on my SI-97 H/S.
I am no longer overclocking my processor or ram. My Video card is slightly overclocked. to 400/1000. with no volt mod.
If anyone needs any more information, i'll gladly reply in hopes of figuring this annoying problem out.
