- Mar 3, 2004
- KHalifornia
homer77 said:hehe, ok.
i'll pull off the heatsinks tonite and see. if i pull off the heatsink will that invalidate the warranty? also, how reliable is atitool?
Quattro said:Let us know.
You gonna OC it?
HousERaT said:The best link i've seen on the subject is here....
http://www.rage3d.com/board/showthread.php?t=33762838
i just checked out the xt bios link here, so i am wondering which bios suits better for my sapphire 9800pro? does the manufacturer specific bios matter at all? also it doesn't have any 128mb xt bios, so would it be any problem using 256mb bios?
is heat gonna be a problem without vga silencer? i m holding back on getting one 'till the new version is out.
felinusz said:There are no 128 MEgabyte XT cards, and as such no BIOS for them. you;re best off overclocking your card for starters, doing some benching, and seeing how high it will go, and *then* flashing with an XT BIOS and seeing if it gives you any gains in benchmarks, and overclockability or not.
