- Aug 30, 2004
- Santa Barbara, CA
"Issues" with Conroe ES chips to be rectified in retail version [New stepping]
Folks,
I came accross this:
http://www.hkepc.com/bbs/itnews.php?tid=627088
What does he mean by having probblems when full system loaded? Is it problem when the system is loaded or is it when the system is not loaded? Any of you ES boys see any problems?
I presume that memory issues are not limited to the P version of the chipset. So end of July it is, eh?
Folks,
Intel hints that Conroe is going to release at B-2 Stepping as Intel Core 2 Duo processor. As for the previous version, a problem was found to make the system full loaded. It’s only solved in the new stepping. We don’t encourage anyone to buy the engineering sample from the web. The retail version is going to release in the end of this month, and it’s much stable.
Further, some of the manufacturers noticed that the released Intel P965 chipset has got the expected performance from Fast Memory Access technology, performing the same as i975X with DDR2 800. Intel has promised to fix the problem in the next P965 C-2 Stepping, and is expected to release in late July.
With regard to the reports on the weak performance of G965, sources indicate that it is because the driver hasn’t been finished. It’s not the stage to make any conclusion yet. Intel scheduled to add DVMT 256MB support in v14.21, releasing on July 13, Pixel Shader 3.0 and T&L support in v14.24, and Hardware Geometry (Vertex Shader 1.1/2.0) support in v14.26, where v14.26 is expected to be the final version. Besides, G965 has stepped in C-1 Stepping, yet there are still some problems to be fixed. We expected G965 would be releasing at C-2 Stepping. It’s very soon to the releasing day (July 23), but it seems the progress is still far away from expected. Whether G695 could release on time is a big question!
