- Dec 20, 2003
- London, England
blackjackel said:If it fails.... try try again...
It didnt work for me either at first (nor for my freind)
i had to put more JB weld on it and wait for it to dry, it worked the 2nd time.
My freind says he had to take off and put back on his hot glue 5 times for it to work correctly.
Dont spend $50 when you can spend $3 for some jb weld or a cheap 99Cent store hotgluegun and some gluesticks...
I'll bet you it will work the second time, try giving it more time to dry or use different glue, JB weld works wonders and is the strongest non-military epoxy on planet earth (i think).
plus its only like 4 bucks max!
blackjackel, in case we can find somewhere that stocks it in the UK, which of these (9) products are you refering to when you talk about JB weld?
http://www.jbweld.co.uk/files/products.html
