- Jan 14, 2006
well here is my new board and memory plz let me know what you all this your opinion matter to me ty all
also this is an Abit AX78
Field Value
CPU Properties
CPU Type DualCore AMD Athlon 64 X2
CPU Alias Brisbane
CPU Stepping BH-G1
Engineering Sample No
CPUID CPU Name AMD Athlon(tm) 64 X2 Dual Core Processor 5000+
CPUID Revision 00060FB1h
CPU Speed
CPU Clock 3000.2 MHz (original: 2600 MHz, overclock: 15%)
CPU Multiplier 12.0x
CPU FSB 250.0 MHz (original: 200 MHz, overclock: 25%)
HyperTransport Clock 1250.1 MHz
Memory Bus 500.0 MHz
DRAM:FSB Ratio CPU/6
CPU Cache
L1 Code Cache 64 KB per core (Parity)
L1 Data Cache 64 KB per core (ECC)
L2 Cache 512 KB per core (On-Die, ECC, Full-Speed)
Motherboard Properties
Motherboard ID 01/17/2008-AMD770-SB600-6A66AA1AC-12
Motherboard Name Unknown
Chipset Properties
Motherboard Chipset AMD RX790, AMD Hammer
Memory Timings 6-6-6-18 (CL-RCD-RP-RAS)
Command Rate (CR) 2T
SPD Memory Modules
DIMM1: OCZ XTC SLI OCZ2N800SR2G 2 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
DIMM2: OCZ XTC SLI OCZ2N800SR2G 2 GB DDR2-800 DDR2 SDRAM (6-6-6-18 @ 400 MHz) (5-5-5-15 @ 333 MHz) (4-4-4-12 @ 266 MHz)
BIOS Properties
System BIOS Date 01/17/08
Video BIOS Date 02/29/08
Award BIOS Type Phoenix - AwardBIOS v6.00PG
Award BIOS Message
DMI BIOS Version 6.00 PG
Graphics Processor Properties
Video Adapter nVIDIA GeForce 8800 GT
GPU Code Name G92GT (PCI Express 1.0 x16 10DE / 0611, Rev A2)
GPU Clock (Geometric Domain) 602 MHz (original: 600 MHz)
GPU Clock (Shader Domain) 1512 MHz (original: 1512 MHz)
Memory Clock 900 MHz (original: 900 MHz)
Field Value
CPU Properties
CPU Alias Brisbane
CPU Stepping BH-G1
CPU Speed
CPU Cache
Chipset Properties
SPD Memory Modules
BIOS Properties
Award BIOS Message
