Having used both, you're unlikely to notice very much difference just browsing the web. Where you'll probably see a difference is for LAN use, but it's more like a few % difference or less for typical traffic.
Given how cheap server NICs are on Ebay, I suggest just getting one. I wouldn't recommend the two port Broadcom since I had one go flaky (suspecting corrupt firmware), which I'm going to swap out for a quad port Intel when I have time.
If you really want bandwidth, check Reddit's homelab section for advice on how to use cheap Infiniband adapters. Note that it would be a complement to your normal LAN, not a replacement.
