Kind of off topic, but not really. When you're done lapping if you want to make a good shim get some thin gasket foam slightly higher than the core and glue squares to each corner. Then sand each corner until each one is level with the core, i used a light and level heatink to test. Then you have a very accurate shim for resting the heatsink.
edit, I mean light, as in a light to see the gaps between heatsink and core, not light as an adjective for heatsink
