uber that was the 5th reaply and the others were not bad applys it could have been a better break in though now that i think of it i ran f@h for a few hours instead of just some counterstrike i probably got the 2 c then because the writing imbedded or burned into my core seemed to be a little moe prominant than 3 of m friends xps. and ive only ever used as3. from the first time my processor ever hit the soket and hsf. and so on it was all brand new it could have also beenmy proc setting in then. and the fact is that the xp cores are so smooth that by lapping it with the 600 grit i added a lot of surface area. and yes ur rigt we use 600 to get those tiny scratches, and if you lap till 2000 grit ur finish will be so mirrored that it willl hold in or repel heat in some way. i totally agree now that you pointed that out to me but howevere when did it several other things were done so the combined drop may have caused the 10c and i like my 43c max load air cooled temp much more than the 54c.
