Roofles said:
Your power supply says 0-30V, isnt there a knob there that will let you change the voltage? Or is it not exact enough for your liking?
Also you could use a multimeter on the outputs and then adjust the voltage so you know you are getting exactly the voltage and current output you want/need.
The unit you refer to is a testing unit. I intend to keep that. I am trying to figure a way to be able to use 9V OR 12V (unregulated .. so like 16V OR 19V) to power various numbers of LEDs. Pipe dream I guess.
Right now I have 19V @ 500ma ... I am looking for 3.6V @ 400ma
I have several 1W resistors in series and paralell to get 90R
I originally planed this for 9V (16V) and bought a 12V (19V) PSU by accident.
When I hooked up my testing unit, I had to dial it up to 16V (current didn't matter except when below 20ma x 20 LEDs = 400ma) but that reading changed alot when I opened the circuit .. it was maxed at 30V ... I think because the rope already has 1W resistors at the beginning adding up to 90R?
The picture with the toilet is the rope I'm havin trouble with.
So in order to light up my 5000mcd LED rope I calculated ...
Requirement: 3.6V @ 400ma
LED specs: 20 x 20ma = 400ma
Since I have already installed a 90R and the lights run perfect with 16V (measured while closed)
My new Requirement is 16V @ 400ma
I have a 19V @ 500ma supply. 19V @ 500 - 16V @ 400
So I need to add a resistor to remove 3V @ 100ma
That works out to 30Ohms using THE LAW.
I just don't want to fry my lights, since they are already installed in the wall. I did this a while ago and I'm not 100% sure about my previous calculations. So I would love a little clarification.
Sangram .. you seem to really know what your talking about. Perhaps you can steer me straight. I learn real quick
