- Dec 13, 2005
Ok, this is going to be a novel, so make sure you have some free time. I'm putting this here, since as of now, live CDs work fine so I doubt this is a direct hardware problem.
The other day I tossed together a basic PC to drag to a LAN a couple times a month (desktop is heavy, too lazy to unplug/replug everything, and I tend to break it whenever I move it). Before spending the $$$ on a copy of Windows I thought I'd see what games I have that would run through linux/WINE.
So Friday, got the parts, tossed it together and went about installing Ubuntu. It was going fine until I restarted and got an "hd0 out of disk" error and a "grub recovery" command prompt. The weird part being after rebooting a few times, the Ubuntu splash screen and was able to log in fine. Checked, just over 90gb free. Restarted, back to "out of disk" and the cycle continued. Tried reinstalling Ubuntu and got the same results.
So now I figure it may be something hardware based. Decided to switch over to Kubuntu since I don't like the new gnome look and just ran the memtest86 that came with it. After a couple hours, I checked on it, and looks like one of the sticks of RAM is defective. Thinking that was the problem, I shot an email to G.Skill, popped out the dead stick, and started installing Kubuntu.
A third to a half way through the install, got an error message. Don't remember exactly what it said, but it was along the lines of "the disk has entered read-only mode. Unable to complete the install." Thinking this meant the SSD was also defective, I plugged it into my desktop as a secondary drive. It mounted fine, I was able to format it, check disk came back clean, and the OCZ update tool said it was already running the newest firmware.
Tossed it back in, tried installing Kubuntu again, and the install went through alright. Reboot, solid, unblinking cursor, system appears to be frozen. Reinstall again, same thing. Downloaded Overclockix (bunch of fun stuff on this thing, thanks to whoever contributed to it) and booted off of it. Ran the built in Disk Utility's self check on the SSD, and like Windows it didn't find any problems. Also, I know it's not long enough but I've been running mPrime for about an hour now and it hasn't picked anything up yet.
Any ideas? I've heard there's something you have to do with Windows X to get it to play nice with SSDs, do I have to do the same with linux?
It's the PC in red in my sig -
AMD PII X4 965
8GB G.Skill Ares (originally 2x4gb, now just 1x4gb)
MSI 760GM-P34(FX)
120GB OCZ Vertex 3
MSI 5850 OC
AMD PII X4 965
MSI 760GM-P34(FX)
120GB OCZ Vertex 3
MSI 5850 OC
